Adjusting the motion curve of an elastic motion
https://forum.reallusion.com/Topic414560.aspx
Print Topic | Close Window
By Hookflash - 7 Years Ago
Is it not possible to adjust the motion curve of an elastic motion? When I open the Elastic Motion Editor and click the Motion Curve button, selecting a different transition curve has no effect (the one that the elastic motion loaded with always remains selected). I'm using the trial version, so maybe the issue has been fixed in the full version?
Well, I submitted this issue on the Feedback Tracker (as we're always being told to do), and it was closed as "not a bug." The only info I was given was two links to the user manual (one about the Elastic Motion Editor, and the other about transition curves). Either I'm not understanding the problem, or the person who closed my bug report isn't understanding it. So to repeat: According to the manual:
"The Elastic Motion can be edited through the Elastic Motion Editor..."
"Click this button [the Motion Curve button in the Elastic Motion Editor] to switch to the Motion Curve panel for adjusting the transition method from the start point (blue bounding box) to the end point (black bounding box)."
When I try to do the above, I am unable to change the transition curve type. Clicking on a different curve type has no effect (the current one remains selected).
*bump*
Is no one else having this issue? Can Reallusion at least acknowledge that they're looking into it? It seems like kind of a deal breaker for anyone who's looking to do any serious work with CA4...
By Peter (RL) - 7 Years Ago
Hi...
Thank you for the feedback.
I have checked the issue you mentioned and can also repeat the problem so this does appear a bug. I will pass this back to the CTA team to investigate. Once I have more news I will update again.
Apologies for the inconvenience caused.
Peter (RL) (6/6/2019)
Hi...
Thanks!
UPDATE: The issue has been confirmed by the CTA team. We plan to fix it in the 4.1 update which is due soon.
Please accept our apologies for the inconvenience caused.
