FaceWare with motion capture
https://forum.reallusion.com/Topic413866.aspx
Print Topic | Close Window
By Gabulous - 7 Years Ago
Hello people!
I want to create a realistic animation movie with motion capture and also facial capture.
Is it possible to connect a GoPro to the motion capture suit and make it record the face of the person using the mocap suit LIVE wireless?
Is the faceware software also suitable for recording faces while the person is moving around? Since i only see demo's of people sitting down and using the faceware.
Gabriel
By Kelleytoons - 7 Years Ago
You can't use a GoPro -- you need to either use a wired Webcam (with FaceWare) or, if you go the iPhone X route, you can do it wirelessly.
There are some videos out there showing the wired Webcam with the Perception Neuron capturing together, if you want to see how it works.
Ow thats kind of misleading on the website then, because on the website it says:
  • PC Camera Tracking: Use PC cam, GoPro or ProHD cameras to live capture facial animation.
By mtakerkart - 7 Years Ago
I think you can use a Gopro if you use the video or image sequence recorded with it. Faceware use video or image sequence or wire  live webcam connected.
You could indeed use such an image sequence, but then the whole point of doing it would be negated, as you'd have to sync it up with the body mocap (so might as well do separate).
I have a video tutorial on how to do this.
Gabulous (5/24/2019)
 What website?  Reallusion's?
yes it says it on reallusion's faceware website: https://mocap.reallusion.com/iClone-faceware-mocap/https://forum.reallusion.com/uploads/images/d92f86e2-2f77-463c-a5cc-c807.png
Would i be able to record face and motion cap at the same time when i use different programs?
Like use Reallusion faceware for the face animations and then use a different programs not from reallusion for capturing the body, and then make them record at the same time.
