By wans7r - 7 Years Ago
Hello, i has problem about creating a character. I open using draw plus 8x due test i just export to swf format without modify it. when I import character to Crazytalk Animator 4 this is the result. anyone know how to fix it? hope someone can help me to fix this problem. thanks.
By vepop - 7 Years Ago
I am not sure whether DRAWPLUS X8 will work with CTA4 in creating a G2 character. In this video tutorial by Reallusion, DRAWPLUS X6 is used: https://www.youtube.com/watch?v=zJPavtRr3YI
Thanks.
By Save the spaceman - 7 Years Ago
Drawplus 8 will work but you have to get an earlier update apparently!
I already follow all instruction propertly..
I think this is the leatest..
By brothertcoleman - 7 Years Ago
I had the same issue,importing SWF from DrawPlus 8 into CTA3 and CTA4. Did you report this in the Feedback Tracker ?
Hello Looking at Jeff's post from last year, you need Drawplus X8 V14.0.0.19 It works fine for him.
If your using DPX8 v14.0.1.21 There is problems llke you are experiencing.
I reinstalled DrawPlus 8 and didn't install the update so it works but it didn't import the hands,but can apply new ones in CTA4.
