By island20012002 - 5 Years Ago
Hi guys i'm new to iclone but i have a question can i use iphone x and kinect togther in the same mesh?
By Kelleytoons - 5 Years Ago
Not at the same time. There is/was a Kinect plugin for iClone, but AFAIK it doesn't work with Live, which is the overall hub for running mocap that the iPhone X capture will run Live Face with.
So you could capture your body movements (assuming you have this plugin and it still works with iClone -- they are pretty good about backwards compatibility so I suspect it does work with the latest 7.4) and then capture the face separately and put them together.
