By dann84 - 5 Years Ago
Is it normal to have 1-2 second delays when browsing through content. Happens when theres alot of files in a folder. I do have alot of saved content. Should I tidy my files into smaller subfolders? There doesn't necessarily need to be anything in the viewport Why is iclone this sluggish.
By Peter (RL) - 5 Years Ago
Hi...
Where is your content stored?
I have found if you use external drives you can encounter slow responsiveness, especially if the drives power down when idle. This can be a real problem when each time you try to browse through Content Manager you have to wait for a second or two for the drive to power up again. You will probably find it best to have your content on a fast internal drive, and preferably an SSD drive for increased speed.
