Move that Camera - Plugin
https://forum.reallusion.com/Topic412791.aspx
Print Topic | Close Window
By The-any-Key - 6 Years Ago
With this plugin you can record movements with your mouse, keyboard and joystick and apply the recording to cameras and props. It got some basic features like wiggle and orbit.
Trial: https://marketplace.reallusion.com/move-that-camera
Update 1.4:
Flight mode, quaternions to avoid gimbal lock, apply only specific parts of a recording.
By 3dtester - 6 Years Ago
For some reason, the plugin doesn't work as expected here.
I am using iClone 7.6 and already had the 'time transformers' plugin, which works.
The problem is, the camera or prop doesn't move at all.
I tried to map different controls (gamepad, keyboard, mouse), but no success.
Additionally, iClone crashed two times since the plugin was installed.
3dtester (9/1/2019)
I will run some tests, can be something new in 7.6
Thanks, i watched the tutorial a few times.
So, from what i have tried, i should at least have seen some movement.
It didn't even work with a simple sphere prop,
By wires - 6 Years Ago
Try the advice given in this post:
https://forum.reallusion.com/FindPost420813.aspx
Oh it's magic! Unchecking the 'reduce idle load' option makes the plugin come to life :)
wires (9/1/2019)
Ahh, hopefully we will be able to detect this in the API in a future update so we can give the user a message about it.
Version 1.5 is now live:
Gravity settings
Apply recording progress
Save and Load remember last folder
Since i installed the 1.5 update, the plugin doesn't show up in iClone anymore.
I extracted the files in the plugin folder, overwriting the old files.
Then i started iClone in administrator mode a few times.
It must have installed a dozen additional Python modules. Is this normal?
However, finally it has disappeared from the plugin menu.
Also, the Time Transformers plugin doesn't work anymore.
Maybe the trial period is over?
Thanks,
3dtester
"Move That Camera" is built on my new base library and will install additional Python modules so this is normal.
If the plugin won't show up in the menu or if the version is wrong or it malfunction, the first thing you can try is to remove the plugin folder and re-install the plugin: https://youtu.be/Kpl_SrYLpww
But if a clean install wont work. Here is how the install procedure should go:
1# After you installed the plugin (replace old files) and start iClone in Admin mode. You will get several messages on plugins that need to be installed.
2# Click OK on one by one. When all is done close iClone.
3# Start iClone in normal mode (not admin mode) and you should not get any messages that there is modules that need to be installed.
(If you still get messages that plugins need to be installed leave a comment or screenshoots on what the messages say.)
4# If iClone start without any "install module" messages, but the plugin don't show up in the plugin menu, there might be an issue with folder access rights. The plugin set up this automatically, but Windows sometimes refuse to use them.
In this case follow this video: https://youtu.be/madVsFscvyw
5# If the plugin still won't show up we need to check the error logs. I have not implemented a thing for that in the current release, so get back to me if that is needed so I can update the plugin with the needed log features.
Has Time Transformers disappeared from the menu too?
Alright, i followed the video guide and did a clean install of both plugins (also set the access rights in explorer).
'Move That Camera' now showing up again and working (thanks for adding the gravity feature!!)
'Time Transformers' didn't disappear, but it doesn't set transform keys for my props.
It just doesn't do anything, as if i had enabled 'reduce idle load'.
Here is an excerpt from the console log, maybe it has something to do with it:
Traceback (most recent call last):
File "E:/Program Files/Reallusion/iClone 7 Dev/Python_API_073_for_iClone_741/Bin64/OpenPlugin/TimeTransformers\l1l11llllll_tt_.py", line 6508, in l111llll1l1_tt_
File "E:/Program Files/Reallusion/iClone 7 Dev/Python_API_073_for_iClone_741/Bin64/OpenPlugin/TimeTransformers\l1l11llllll_tt_.py", line 6501, in l1lll11111l1_tt_
UnboundLocalError
local variable 'l1ll111lllll_tt_' referenced before assignment
EDIT: this only happens with specific props. I have renamed them, so might this be the reason?
I will check the error in Time Transformers.
I the meantime you can try right click the prop and click "Remove Object Animation" and try after that (sometimes the animation clip get corrupted in iClone and can't be processed by the Python API). I will add so the plugin automatically check if the clip is corrupted in the next update.
Note that if you load a prop into Time Transformers and later rename the prop in iClone. You need to select the prop in the plugin and in iClone, and click the "Replace selected" button in the plugin (because the plugin can not know if you change the name on a prop). If you try save the time transform tree and later load it, you should get a message that some props can't be found because they don't exists or have changed name.
Well, what i found out is that it only works if i detach the props from the main object.
I've been convinced that 'Time Transformers' supports sub-props.
But it stopped doing so since i updated both 'Move That Camera' and iClone (7.6.1)
3dtester (9/20/2019)
Linked props should work. But subprop (attached) cause the python API to go havoc. This has been a problem from the beginning. Hopefully they fix this in a future version.
Thank you, that's really good to know.
I can workound this, but for bigger projects it could be problematic.
