By Rampa - 5 Years Ago
Here is the Persona with the move commands. You can add it to either your Template or Custom Persona folder in Windows Explorer if you want it in your Content Manager. https://drive.google.com/open?id=1okGh-cMSTy8MQC-rURh5uBdH5NAOU5Ki
By 3DChick - 5 Years Ago
Thank you for the video and personal file--I feel like I understand them much better now. One question I can't seem to find the answer to (I may not know the right terminology to search properly) is I've used a persona walk, but then tried to add a persona idle to the end and the character jumps around, like back to the start position. I'm sure I'm doing something wrong, but I'm not sure what it is. Any tips?
Thank you!
If you mean an Persona idle command, I don't they work anymore.
If you're adding an idle motion, and it's showing up in the wrong place, make sure all the options in the "Animation/Motion Setting Options" menu are checked.
Thank you for the suggestion, although I am not actually sure where to find the "Animation/Motion Setting Options" menu. Yes, I am that new...Today I did get it to work, the persona walk blending into the idle, but then I realized the character just looked like he was moving--he hadn't actually gone anywhere.
I will keep messing with it. :-)
By Pollux - 5 Years Ago
That's GREAT Rampa, very useful so thank you.
By TopOneTone - 5 Years Ago
Thanks for this Rampa will come in very useful. Cheers, Tony
By sjonesdc - 5 Years Ago
Rampa, Could this be done with any of the previous Persona files? I know that one would need to change the lines for the motion directories AND could this be done with any of the Animals of the World characters?
