Texture disappearing when importing into UE4 with morph targets
https://forum.reallusion.com/Topic409684.aspx
Print Topic | Close Window
By jacobroebuck - 7 Years Ago
I imported an animation with a viseme track to UE4 and the mouth movements didn't work right. Reimported with morph targets on. Now the animation works but the material fails to load properly when I play the level. Any thoughts on what is causing this and how to fix it? Thanks!
https://forum.reallusion.com/uploads/images/e1918de4-dc90-468d-b978-3160.png
I can change the material and it still doesn't work. FYI.
SOLVED: In the material editor in UE4 under usage you have to check use with Morph targets with all the textures related to the head.
https://forum.reallusion.com/uploads/images/aaae39cb-a036-4798-bb91-6312.png
By jinpark.dev - 3 Years Ago
you saved my life
