By denise.wilson1 - 5 Years Ago
Can you change the hair color in Crazy Talk 8?
Also, can you use content packs for CTA3 and/or iClone in Crazy Talk 8 Pro edition?
By Peter (RL) - 5 Years Ago
Hi Denise
You can change the Hair colour for a 3D Head by going to Create > Accessory Settings from the Menu Bar. You can then adjust the Hue, Brightness, Saturation and Contrast to change the colour. In addition, you can also save the texture map for the hair and edit it in an external image editor. For 2D heads, you will need to make the changes to hair colour in your source image prior to creating the 2D Head.
Unfortunately due to the different file formats used, CTA content is not compatible with CrazyTalk 8.
