By Nosycat - 7 Years Ago
Hi All, I was watching this YouTube tutorial and decide to try it. CrazyTalk Animator 3.1 Pipeline Tutorial - Create a Prop with Hierarchy"Sadly, when I create a media only the first layer in my image folder imports, all the other layers are missing. Can anyone advise please?
I did it with only 2 petals and a circle still only the circle will import :(thanks in advanceKim
By Peter (RL) - 7 Years Ago
Hi...
The tutorial works fine so if you follow it carefully you should be able to reproduce what is shown. You should try to watch it a few times to fully understand the steps involved.
Try first loading the sample Flower.PSD which is shown in the tutorial and import this into Crazytalk Animator 3 without making any changes. This will confirm that the import process is working correctly. Then with the Flower.PSD open in Photoshop, try replacing the images in the RL_Image group with your own images but don't change the structure of the PSD in any way. This should allow you to import the flower again but this time with your own images.
Do give it a try and if you get stuck, please tell us at which point in the tutorial you have problems.
Hi Peter, Thank you very much for your response, appreciate it. I was being stupid, I've imported the prep-compound prop and discovered my error, it's by not paying keen attention. In the Pivot points folder, the commands Flower is > than petal, was my issue. I had none of those.!! once again thank you very much for answering
Happy animating Kim
Hi Kim
Great to hear you have resolved the problems you were having. Thanks for letting us know. :)
By mdent - 5 Years Ago
I'm having the same problem My Scene Manger only shows Prop with what ever name of the file of the psd is named. I am using Photopea. This is the Leaves(0).psd from the Beach demo. (There is also leaf_02 and leaf_3). In Photopea the structure is there but when I bring it back in through the pipeline to Scene Manager the structure is not there.
File Structure Photopea RL_Pivot (Folder) Dummy Dummy>leaf_01 ObjectPivot RL_Image (Folder) Folder leaf_01 (Folder) leaf_01 Dummy (Folder empty)
File Structure Scene Manger Cartoon Animator 4 Prop Leaves(0)
I could not locate the Flower.psd file as I have Cartoon Animator 4. Window machine
