Help! Problem with my character with foot. i PLACE T POSE AND THE FEET KEEP ON THE WAY FOR HIGH HEEL AND ii WANT TO PLACE THEM LOW HEELS .
https://forum.reallusion.com/Topic408347.aspx
Print Topic | Close Window
By cynsegura - 5 Years Ago
https://forum.reallusion.com/uploads/images/6db81398-2a50-46ee-bdb5-b9e8.png
By Kelleytoons - 5 Years Ago
Might need a little more info on this.
First of all -- what character?  What clothing?  How did you bring the character into CC3?  (Or create it).  Showing us a screen shot of the entire character outfit would also be helpful (show the modify panel and morphs, along with the scene panel expanded).
Thanks always for your great support!
I created the character with character creator. It is the model from character creator.
I also have problems with mesh if I want to place her boots.
All the outfit is working with other characters.
https://forum.reallusion.com/uploads/images/1f73eb57-c10e-4078-8b5e-ff35.png
https://forum.reallusion.com/uploads/images/cf6c0ed2-eff9-4e46-a39d-4de1.png
i did weight map, confirming and all the options. But all look awful to place the boots well as I showed on the photos on the other post.
Thanks a lot always for your kind help!
What boots are those?
As to the original problem, it looks like you have the boots on and are then either deleting or hiding them (so the feet are up).  If so, before you delete or hide you need to lower the heels using that option in modify.  But first let me know which boots you are using.
I am using the boots that come on this pack
Professional Outfits-Cloth Bases for Character Creator (Export Version)
The problem is that I cannot modify the feet position. when i place t-posse is still the same, deleting also the boots. I cannot find the way to change that feet position, from there all the problem comes.
What do you suggest to me to be able to change feet position and go back to the original.Thanks!
https://forum.reallusion.com/uploads/images/2de60f71-e0f1-40bb-b51d-4d63.png
Okay -- but there are a LOT of shoes in that pack.  Which shoes in particular are you using?
the problem is on the bones from the feet. How can i fix hat problem and make the feet to go back to original position as the one they have it
That problem I believe it came when I placed the boots. It brought desiglimentt that I cannot find a way to fix it.
https://www.reallusion.com/contentstore/iClone/pack/ClothBaseForCharacterCreator_ProfessionalOutfits/contentoverview.html?category=Presets
Here I send you the folder. Maybe you can have a look and see how I can fix this.
I love this character. I was working a lot on this one!
https://www.plustransfer.com/download.php?id=baba2b4b0f48d1671d8c8cc18ebdf406&email=v%C2%8C%C2%81%C2%86xz%C2%88%C2%85tSz%C2%80t%7C%7FAv%C2%82%C2%80
I think that the problem on the bones came when in 3d exchange I modified the eyes expression. As the eyes are very big. I had to modify them on 3d exchange. It looks like I forgot to place them on the ground.
I just went to 3dechange but I cannot find the way to go back to t- pose original.
Thanks a lot for your help!
Yeah, and you've got some sort of custom content (with a tongue, no less!) that I don't have, so I can't modify this character or even test it out.
My plan was to export to iClone and see if I could rotate the foot bones there, and then export from there back to CC3.  But I really can't help you now.
Thanks a lot!
I did that! But It doesn't work out!
i HAVE THE ORIGINAL WITHOUT ALL THE WORK i MADE IT BEFORE SENDING IT TO 3D EXCHANGE.
So I will work on that. Instead of trying to sort out this. That I cannot find the way.
Thanks a lot anyway for your help!
Hi Kelly toons,
Finally, I found when this happened. It was when I exported to ZBrush.It can be modified in ZBrush.But anyway. I created a much nice smother face and morph.
I only let you know, because I see you a super active member.
If you use zbrush never send a character with high heels. It will change all bone structure and will produce this problem.
Have a great day!
