How to import OBJ file as clothing in CC 3.04?
https://forum.reallusion.com/Topic407887.aspx
Print Topic | Close Window
By animagic - 7 Years Ago
I'm a bit stumped...:unsure:
For a forum member I'm researching creating clothing from OBJ files in CC, which I have done previously, but I wanted to it again to be sure of the steps.
In CC 3.03, I could import an OBJ file to serve as clothing. It was an option under Create, where I could then select Cloth, Hair, Acc with the option to either import an OBJ or an FBX file. Very simple...:Wow:
In CC 3.04 , the option is renamed Cloth, Hair, Acc (with FBX key) and it is no longer possible to import an OBJ file. I believe Rampa mentioned what to do instead, but I don't remember... :blush:
By Kelleytoons - 7 Years Ago
Import as an Accessory.  Then change by adding weights to cloth.
Kelleytoons (3/19/2019)
Thanks. Yeah, in the meantime I've read the manual...:blush:
I wished, though, that they called the option something else...:unsure:
