Can not render animation in Final Render quality
Home
Archive
iClone 7
Technical Issues
https://forum.reallusion.com/Topic407815.aspx
Print Topic
Close Window
By dakkar107
7 Years Ago
Hello!
New user stumbling my way around. I have the Iray rendering plug-in installed and I can render an Iray preview of a single frame. When I go to render my animation, I select "Final Quality" for my output, but the output is only in Preview quality. I don't want to start blindly changing settings; any ideas what the problem might be?
By animagic
7 Years Ago
I am a bit confused. The quality of the Iray Preview render is the same as that of the output for specific settings.
You are talking about a "Final Quality" setting, which I don't see. There is a "Final Render" setting, but that only applies to the iClone native renderer.
Note that the size of the Iray render can be selected to be either determined by the iClone Preview window or by the iClone render size.
By dakkar107
7 Years Ago
Thank you for answering, sorry about the confusion.
I did mean the "Final Render" quality. Still stumbling around the terminology and usage.
What I'm trying to work out is how to render the animation in Iray, rather than the iClone native rander, I guess.
By Kevin.S
7 Years Ago
By dakkar107
7 Years Ago
Thank you very much!
By Kevin.S
7 Years Ago
dakkar107 (3/20/2019)
hope it helps :-)
