By matasoy - 7 Years Ago
CC3 sometimes goes to trial mode and we can't use some features or we can't save files. Also we have a OBJ problem. We can not import OBJ file, there is no import option for OBJ (Just FBX) on the Create menu (Cloth, hair, acc). But there is a lot videos on youtube importing OBJ files. Is out licanse key broken or someting?
By Peter (RL) - 7 Years Ago
Hi...
Can you explain more about what happens to Character Creator 3 that makes you think it has gone into a trial version? Do you mean you have a watermark onscreen for some content? If possible please try to provide a video clip showing what happens or some screenshots that show the issue. Do also confirm that you have purchased "Character Creator 3 Pipeline" (the Standalone version).
Regarding the OBJ issue, please use Create > Accessory when using OBJ files. This is described in more detail HERE.
the serial in our account is not used, but when you open the application the application appears to be active. We think that's the problem. We uninstall and reinstall the program. We think it's a connection problem. uninstalled the program and setup it by using the Reallusion Hub, enter the user account, nope, still seems not activated. After reinstallyou can see the about screen. The serial on the about screen is not the same on account screen by the way.
By 783482203 - 7 Years Ago
i have the same error...
