By omegaav - 7 Years Ago
I have made a model in Adobe Fuse and then rigged in mixamo but when I open it in 3d Xchange the character has its hands above its head and is all corrupted. look at image
I am new to all this so any advice/tips will be appreciated
By Kelleytoons - 7 Years Ago
How did you map the bones in 3DX?
Hi,
Once I have brought it in I select Character/Convert to Non-Standard, there are no presets available they are all greyed out
Then I select apply to iClone
As I have said I am very new to all this, and in addition into my 60's so age may not be on my side!!!
You have to map the bones yourself. Let me see if I can find a video tutorial on this process:
Okay, found one. Look at the 1:50 mark here and it should explain what you need to do. Let us know if you have any difficulties with this process:
I followed the video, but I still cannot select any of the bones, the dot in the top left corner is green compared to the video where it is red.
I have tried with and without animation but still no luck, I will re install the software just in case there is a problem there but any further help would be greatly appreciated
You might have to post a link to your model -- I don't know what else to tell you (but if the bones are green try turning off the t-pose and see if that allows you to then select them properly).
I have turned off T.Pose and the legs disappear.
There are a number of animations which I can select but all of them look like the initial image i posted but they are moving, they resemble an inflatable doll.
How will i be able to share the link to my model as you have suggested, I am quite happy to allow someone to take control of my computer to see if its something I have done.
I have noticed that if I use the y.bot character rather than a character i have made in Fuse it works ok
Just upload your model somewhere -- there are a lot of free cloud services (I like Mega). Then provide a link to it.
Thanks for your help here is the link:
https://mega.nz/#!itl1FQ6I
I have just tested it in cinema 4D and it works fine
Hopefully you will be able to find out the problem
You created the link with an encryption key, which I do not have.
You can create the link without the key so that anyone can download, or you can provide the key.
Sorry, here you go
https://mega.nz/#!itl1FQ6I!sK0f4DqOC9H5-tPJzrgLicA3MRufbK9Ee-Wqx63x79A
I *think* the basic problem you have is you don't have a T-pose for that character. Characters must be exported with a T-pose in Mixamo to import again into 3DX.
I'm not enough of an expert to get that model into a T-pose so my advice would be to export again from Mixamo but make sure you also export the T-pose position.
Hi I have now made a model in T.Pose but I am still getting the issue
https://mega.nz/#!KlkwUSrD!l018e88kIIWAOdtBZ4eljbf0OKfxWILzmoFK4a7ohR8
By Skuzzlebutt - 7 Years Ago
the shoulder and thigh bones are twisted try this charactorization file unzip it first and uncheck active then you can load it
By Warped Reality VFX - 7 Years Ago
Hello,omegaav I converted these for you the first one also has weight skinning issues in the fingers but it works, the second seems fine I hope this helps.
hey kevin i have a popcorn question for you about linking the tesla coil particle length to a audio sampler sorry to go off topic edit: nevermind, i figured it out
When i try to unzip it is coming up with an error
Thank you, that worked can you tell me how you did it because I have quite a lot that I want to do and I really would like to be able to crack on and do them.
I think I have found where the problem is, if I setup Mixamo Auto Rigger Skeleton LOD to Standard Skelton (65) I get the corruption. If i set it at 3 Chain fingers (49) or 2 Chain fingers (41), it comes across fine.
Who should I report this bug to Reallusion or Adobe?
By rguy - 7 Years Ago
https://www.youtube.com/watch?v=0lcI2y4EGmE iClone 6.5 Tutorial - Mixamo to iClone Part 2: Importing Mixamo Characters with Animations to iClone
https://www.youtube.com/watch?v=plcJLIxmklg iClone 6.5 Tutorial - Mixamo to iClone Part 1: Importing Motions to iClone
I used these tutorials when working with the Mixamo avatars and motions and didn't have any problem.
Thank you for those links, that explains my problem, what is it about men not reading/watching manuals???
