question about compatibility
https://forum.reallusion.com/Topic405722.aspx
Print Topic | Close Window
By johnwarndt52 - 7 Years Ago
There are props I'd like to buy from the marketplace whose compatibility specs say:
"Compatibility:
iclone v5. (or above)
Required Product:
iclone v5 "
Does that mean they won't work on versions higher than 5.5 (unless, perhaps, you've upgraded from 5.5 to something higher and still have elements of that lower version stored in your computer)?
By animagic - 7 Years Ago
If it is a regular prop, it will certainly be compatible with later versions.
If you point to a specific prop, it will be possible to give additional information.
By Peter (RL) - 7 Years Ago
If it says compatibility is iClone 5 or above, then it can be used with iClone 5, 6 or 7. You won't need iClone 5 installed to be able to use it.
Thanks, guys.
