Is to possible to render mask lighting effect with iray plugin. Because I don't see the tree and the blue background I created when I render with this iray plugin
Home
Reallusion
General
https://forum.reallusion.com/Topic404799.aspx
Print Topic
Close Window
By cynsegura
2 Years Ago
The second one is what I got with iray plugin. Not really happy because I cannot get the mask and light effect.
If someone ones to try to tell me settings. I want to attach the folder. But I don't know how. It doesn't upload here. I can send with webtransfer link
By cynsegura
2 Years Ago
Thanks for your reply. I am using iclone 7. It is with animation I cannot get mask
By animagic
2 Years Ago
I played a bit with this (would be the same for iClone or CC) and it requires changing the setting of the spotlight you are using for Iray and also cranking up its Intensity in iClone.
In iClone I set the Multiplier for the spotlight to 5.0.
In Iray I have the following settings:
The trick for sharp shadows in Iray (which you need for the mask to show) is to have a light source with a small diameter. But the light will be fainter so the Intensity Multiplier needs to be increased.
Iray Preview:
This should help.
By cynsegura
2 Years Ago
Thanks a lot!! Would you like I will send you the file and you play around.. please let me know! Thanks!!
By animagic
2 Years Ago
You're not saying which software you are using: iClone or Character Creator?
By cynsegura
2 Years Ago
By animagic
2 Years Ago
cynsegura (2/17/2019)
I've sent you a PM.
