Need help - Preview shows dark room
https://forum.reallusion.com/Topic403183.aspx
Print Topic | Close Window
By rightdecis - 7 Years Ago
I have a project in IClone that takes place indoors. At first the walls and floor surrounding the room wouldn't even show up in the preview. But then I unselected the room as dummy. And now there is a new problem. Although my project has lights whenever I preview it in Iray it shows a very dark room with the light coming only from the windows and from the one avatar in the project. I can't seem to resolve this issue no matter what I do. This is just the preview I don't want it to render this dark room.
Can anyone help me please?
By Rockoloco666 - 7 Years Ago
That is because iclone light is not entirely accurate but iray is accurate. Your issue is happening because the lights aare outsside your scene. In iray the ibl will generate shadows while the iclone preview doesnt render ibl shadows hence the discrepancy between iclone and iray. You need some lights in your interiors
How do I add lights in the interiors?
By justaviking - 7 Years Ago
rightdecis (1/30/2019)
One simple answer is, "The same way you do at home."  You will need to add "lights" (Create --> Light...)
You can also add some "glowing panels" and stuff like that.
By Renaissance Man Studios - 7 Years Ago
justaviking (1/30/2019)
I'm using the included G6 with Mason and Heidi sitting on the couch. It already has a combination of four lights pre-staged in the scene and I still get darkness. I even tried adding an additional spotlight and still no different. I sure I am missing something.
Renaissance Man Studios (1/31/2019)
I figured it out. I had to deselect the iRay Preview Selected button in the top right. Although that sounds backwardhttps://forum.reallusion.com/uploads/images/bb0f64d3-d188-4f44-9da9-172d.png.
By animagic - 7 Years Ago
I loaded the project and did a Preview render and it showed up OK. I then converted to PBR for looks and rendered again:
https://forum.reallusion.com/uploads/images/9e300fd0-8263-4c4d-a87a-10e0.jpg
So it shouldn't be dark. Could you post a screen capture of the Preview render window?
OK, we cross-posted.
Iray Preview Selected only renders the items in the Selection List under Preview Selected:
https://forum.reallusion.com/uploads/images/22a31943-9bcd-46d7-8008-f5b3.png
animagic (1/31/2019)
Thanks for clarifying!!!!
Although I fixed it, it didn't understand why and now I do.
I've been adding indoor light props that have a glow effect to them to my indoor scenes. It seems to be working. But the size of the props only brings a little light. How can I add a very big interior light?
