Hi,
did anybody manage to install PIP as explained here: http://manual.reallusion.com/iClone/script/python/md_docs__python_extension_libraries.html ?
I found following problems:
1. Updated the system PATH variable as indicated in the doc, adding the path "C:\Program Files\Reallusion\iClone 7\Bin64"
2. Opened the Command prompt
3. I launched iclonepy pointing to the full path to get-pip.py => Command prompt complains for the space in the path!
4. So, I moved to the C:\Program Files\Reallusion\iClone 7\Bin64 and then launching iclonepy from there, pointing sub-path after Bin64, i.e. scripts\Python\get-pip.py
5. The Python script get-pip.py starts, donwloads some files, tries to install pip and terminates with an exception
Exception:
Traceback (most recent call last):
File "D:\Temp\tmpsre17a7t\pip.zip\pip\basecommand.py", line 215, in main
status = self.run(options, args)
File "D:\Temp\tmpsre17a7t\pip.zip\pip\commands\install.py", line 342, in run
prefix=options.prefix_path,
File "D:\Temp\tmpsre17a7t\pip.zip\pip\req\req_set.py", line 784, in install
**kwargs
File "D:\Temp\tmpsre17a7t\pip.zip\pip\req\req_install.py", line 851, in install
self.move_wheel_files(self.source_dir, root=root, prefix=prefix)
File "D:\Temp\tmpsre17a7t\pip.zip\pip\req\req_install.py", line 1064, in move_wheel_files
isolated=self.isolated,
File "D:\Temp\tmpsre17a7t\pip.zip\pip\wheel.py", line 345, in move_wheel_files
clobber(source, lib_dir, True)
File "D:\Temp\tmpsre17a7t\pip.zip\pip\wheel.py", line 316, in clobber
ensure_dir(destdir)
File "D:\Temp\tmpsre17a7t\pip.zip\pip\utils\__init__.py", line 83, in ensure_dir
os.makedirs(path)
File "C:\Program Files\Reallusion\iClone 7\Bin64\lib\os.py", line 220, in makedirs
mkdir(name, mode)
PermissionError: [WinError 5] Access is denied: 'C:\\Program Files\\Reallusion\\iClone 7\\Bin64\\Lib\\site-packages\\pip'
Did anyone succeed to install a Python package using the method described by RL ?
Thanks
Roberto
