By zodiaque1980 - 6 Years Ago
Hi, i use cc3 to export fbx with A pose but when i import it in unreal engine it get back to T pose. Of course when i export it i make sure that i include A motion in custom motion. when i open the fbx file with a dcc like blender, maya and 3dsmax , the character is still in A pose but in unreal the skeletal mesh is in T pose. Please can you tell me why this happen and how should i do to fix this? thank you in advance for your help
By Peter (RL) - 6 Years Ago
Do make sure you are adding the "_OpenA_UE4" pose to the export panel and uncheck the box marked "Universal T-Pose Editing"
Note: You can find the "_OpenA_UE4" pose under Pose > Body in your CC3 Content Manager.
Hi Peter, Thank you for your answer. First of all the pose that I found in cc3 don't have ue4 in it name instead I found this
 And the export conf that I use is
 Neither the _APose or _OpenA didn't work when I exported to unreal. It still keeping the t pose.
By Rampa - 6 Years Ago
You need to set the "Use TOAs ref pose" on UE4 import. That makes it use the first animation frame as the rest pose.
Thank you both of you, Peter and rampa. I finally successfully import in A pose in the engine. Thank you rampa for notifying me to check TOAs option. It work !!!
By JayNyqvist - 6 Years Ago
Is "_OpenA_UE4" different from "_Open A" or "A Pose"? Which one must we use? Thanks in advance.
Yes, it is different. You want the one shown in the video below.
https://youtu.be/-qZsU5jaW2M?list=PLNV5zSFadPdmyOVE2c3RrOqLZS-KfiEZK&t=106
