When you exported from Daz Studio did it generate a folder called Maps with the textures inside?
Also if you refer to the .MTL file it should show the directory structure that points to the Maps folder like in the example below. Does your .MTL file show the correct information?
newmtl sleeves
d 1
Kd 0.69411767 0.65490198 0.59215689
map_Kd /Maps/01LongTShirt.jpg
newmtl shirt
d 1
newmtl trim_bottom
d 1
newmtl trim_neck
d 1
newmtl flaps
d 1
