Hi Stuart,It's great to hear your plans for Crazytalk content. If what you will be creating will be audio only (no image or script) then you will probably be better off with just the individual WAV files containing the vocal impressions.
If you do plan on adding facial images, animations etc then these should be supplied in the appropriate CTM and CTS formats. As I'm sure you are aware you can't use copyright images for your packs so all work would have to be 100% original.
At present there are no audio only packs available for sale in the content store. Take a look at the link below for the submission guideline page and here you will find the contact email if you would like to enquire about submitting audio packs for resale.
http://developer.reallusion.com/submit_all.aspx
Good luck with your packs. :)
Pete
