How do I uninstall on Windows 10
https://forum.reallusion.com/Topic399316.aspx
Print Topic | Close Window
By Ryan Hayle - 7 Years Ago
Windows 10 - how do I uninstall any of the reallusion software? No option exists in the normal uninstall settings. I have the latest versions of everything. All other unrelated software uninstalls fine.
By animagic - 7 Years Ago
You mean you don't see any of the entries such as the following?
https://forum.reallusion.com/uploads/images/047e1a29-b5d5-4f19-b8bd-82b9.png
By Peter (RL) - 7 Years Ago
In Windows 10 you can go to Start > Settings > Apps to find all your installed programs. Then click the one you want to remove and select Uninstall.
Nothing is there to uninstall. The only one I can see in setting - apps is cc3, but the uninstall/mod is disabled.
My hard drive is small and full, so I want to install to a bigger drive.
The hub app uninstalled fine, I could see that one. Faceware uninstalled but did not deactivate within my account. The rest have no uninstaller.
Is there another way to uninstall?
By pka4916 - 7 Years Ago
Make sure you have Admin.
Go to the old Uninstall screen   type control  (so you see control panel)  after hitting the start button.
if it's not there either.
Run the installers,  and remove from there.
Thanks after installing a second copy of everything, I was able to deactivate them. I was never able to remove the original software, but nothing a format can't fix now.
