How do you adjust UV's in CC3 or in my pipleline so my Substance textures allign with CC3's UV
https://forum.reallusion.com/Topic398360.aspx
Print Topic | Close Window
By jfleetwood - 8 Years Ago
I'm hoping that there is a relitivly easy solution to complete my workflow.
First I create a model with CC3 Base
I then send it to Zbrush with GoZ for detailed sculpting.
I save the origional mesh poly count and a HP version.
I then bring the LP into Substance Painter and project the HP detail.
At this point I know that the UV space is wrong. What I'd like to know is if there is a way to either adjust the base CC3 modles UV or is there something I need to do in Zbrush or Substance.
Your help would be very appredciated, I've  been trying everything I can think of.
If I have to bring it back through exchange that would be fine as long as it retains all of the facial bones.
By StudioZ3D - 7 Years Ago
Can you show us how your UV space is messed up? Only issues I've had with Zbrush is that it scales things weird.
By vidi - 7 Years Ago
In Zbrush are the UV overlaped
https://www.youtube.com/watch?v=jqN_ZlMY2OY
