[Curve Editor 1.11 NEW RELEASE] Bugs Fixed
https://forum.reallusion.com/Topic398309.aspx
Print Topic | Close Window
By Tony (RL) - 8 Years Ago
Curve Editor v1.11 - Now Available
Version: v1.11.2330.1 Released 2018-12-24
Several Bugs Fixed:
  • Fixed: Panning in the Curve Editor viewing area caused it to move erratically.
  • Fixed: Inability to use the left and right arrow keys to scrub the timeline when the Curve Editor and the Timeline are both open.
  • Fixed: Adjusting the project's timeline duration had an influence over the Curve Editor panel in subsequently new projects.
  • Fixed: Curve Editor panel added an additional frame to the actual length of the project.
Dear iCloners,
If you are a current user of Full Version Curve Editor Plugin, please UPDATE your Curve Editor Plugin to v1.11 to prevent crashes due to incompatibility with iClone 7.4.
If you are a current user of Trial Version Curve Editor Plugin, please make sure your Trial Version Curve Editor Plugin is v1.11 to prevent crashes due to incompatibility with iClone 7.4.
To know more about Curve Editor Plugin v1.11, please check out its Release Note.
We apologize for causing your inconvenience.
