Rendering in IClone 6
https://forum.reallusion.com/Topic396738.aspx
Print Topic | Close Window
By Dagny - 8 Years Ago
I have 350 frames that render out to half of that.  I have tried various formats with the same results.  What should my render settings be?
By Postfrosch - 8 Years Ago
That's OK.
IClone works internally with 60 frames
If you have 350 frames in IClone,
175 frames are displayed when rendering
2 frames of IClone make 1 whole picture
So the whole project is rendered with 350
Greets from Germany
Postfrosch
Thank you so much for your reply!  The problem is that the results are sped up... like what should have been shown in 10 seconds is done in 5 which is not the outcome I wanted.  So how do I get , let's say, 10 seconds of film to look like 10 instead of condensed into 5 seconds?
By Kelleytoons - 8 Years Ago
Are you rendering to single frames or to a video file from iClone?
Video file and I have tried both MP4 and AVI formats
By Peter (RL) - 8 Years Ago
Dagny (12/4/2018)
If you render a project that is one minute long then when you play back the video it should still be 1 minute long. It won't matter if you render it at 30fps, 25fps or 15fps it should still be 1 minute long.
I would check the playback speed of your media player. MP4 video is always rendered from iClone @30fps so make sure you are playing back at that speed.
350 Frames in RL are not a 10 sec VideoClip
thats are 5,5 sec Videoclip
Greets Postfrosch
Thank you everyone for your help!  While I still don't understand the rendering process in IClone, it ended up working by reducing the clip speed in Premiere Pro.
