Elf On A Shelf
https://forum.reallusion.com/Topic395788.aspx
Print Topic | Close Window
By EvilGenius - 8 Years Ago
So I was thinking of buying an Elf On The Shelf for some content.  After looking into it I realized its really limited on what you can do.  I thought perhaps an iClone Elf On The Shelf character would have much less limitation.  Have any of you heard of anyone who has successfully created an iClone version of Elf On The Shelf?
https://forum.reallusion.com/uploads/images/edcdfe80-75fb-455a-96fa-e66b.jpg
**sigh**
This forum can be so hit-or-miss.
By kungphu - 8 Years Ago
Apoligies but your post is quite confusing. So you were going to buy a physical Elf on a Shelf? Makes sense. But buy it for content?:unsure: Pretyy unclear what lead you donw this path. As far as Elf on a Shelf for Iclone... Seems like the lack of replies is your answer. The face/character shouldn't be too hard with CC3/Daz3D and a sculpting tool (zbrush or 3Dcoat). Not sure of any Elf on a Shelf Clothing. Surely there's something out there? Could always buy one on turbosquid and rig it in MIxamo for free.
By animatedbeing - 8 Years Ago
I found several by searching for "elf on a shelf 3d model". No iClone versions though some might be convertible using  3dXchange.
https://www.turbosquid.com/3d-models/elf-shelf-3d-3ds/985796
https://free3d.com/3d-model/elf-on-the-shelf-244.html
Yep, that’s the one I saw too. There’s a rigged one on CG Trader. But it’s $78!!!! $19 and autorigg in for free in Mixamo or Maya LT (I think you can use the autorigger with a free trial). I could probably make the head or something close. The body is tricky for me with how it’s set up.
