By saavedraerwin - 8 Years Ago
hi guys, i have character creator 3 pipeline. i wish to import a custom animation (because i want to use frames of the animation as poses to adjust the cloth), is this possible? or do i need 3dxchange... if it is the case... do i need (to import) the pro or the pipeline version? thanks!
cheers,
By Peter (RL) - 8 Years Ago
If you wish to import custom animations for use in CC3, then you will need 3DXchange 7 Pro or Pipeline to do the conversion from FBX or BVH into .rlMotion or .iMotionPlus formats. These can then be used in CC3.
hi peter.. thank you very much. my final question is... will 3dxchange pro work? as i am only interested in importing and not exporting the animations (well, i want to export the character... but i don't need the animations)..i know you stated both... but just to be extra sure.. thanks!!
