By videodv - 6 Years Ago
Just wondering if its possible to make a character appeare over time and not just turn the visability on and off.
Cheers Chris.
By Peter Blood - 6 Years Ago
Hi: You can do that with the opacity slider. On frame #1, set all of the avatars components to "0" on the opacity slider. Skip ahead on the time line to where you want him to appear completely and reset all of the components to 100%. The distance between the two settings determines how fast the avatar will appear. Short distance = quickly Long distance=slow.
Hope this helps. pete
By jlittle - 6 Years Ago
There is always the Opacity setting that can be used to fade in and out with.
Jeff
EDIT: Ah, cross post with Peter.
By justaviking - 6 Years Ago
A couple quick ideas: 1) Keyframe the OPACITY channel STRENGTH. However, with multiple materials involved, that might be laborious, though you might be able to multi-select the materials. 2) Do it in your favorite NLE (video editor). Render the scene with and without the character, and blend (dissolve) the two clips in the video editor and the character will "appear" over time.
ADDED: Wow, a lot of simultaneous responses being typed.
By Kevin.S - 6 Years Ago
here is a quick sample
By Clark - 6 Years Ago
I have done this by selecting the character and changing the opacity of all associated items (selected all at once). There have been times when I wanted to manipulate the opacity that I would need to work with attached items individually.
Late again
Thanks Guys most helpful.
Cheers Chris.
Here is a very quick and dirty test Hopefully you will be able to see it.
So thanks once again guys Chris.
Edited to remove video. Edited to re-add video.
Oops... Your video cannot be viewed. It is probably marked as "Private."
