By Peter (RL) - 8 Years Ago
Elite Characters - Human Bases in Celebrity Style - Now Available 10 Gorgeous Characters in Different EthnicitiesThese 10 highly detailed digital human characters are designed in chosen celebrity styles. Not only they look gorgeous, you can freely blend between their morphs, mix them with other hair, outfits, accessories to best present your character for live mocap, real-time animation, or artistic render.    Main Features :● RTL Eye System - this new eye system provides ultra realistic real-time eye render in a 3D scene that is purely lit up with real lights. RTL eyes work for both shader modes. By default, it’s in Traditional Shader mode, which is optimized for real light reflection. You can also switch them back to PBR shader mode for IBL reflection. Please watch this video to know more about RTL design. ● Unique Eyes and Teeth - Each character has its own unique eye material settings corresponding to his or her face shape and ethnic origin. The gum and tooth structure are individually adjusted to best fit each face shapes. ● Skin Preset and Skin Morph - Both Skin Preset and Skin & Morph Preset are provided for full body and head only. Most notably you can use the Head Skin Morph to switch avatars’ head, so that the body skin color can naturally follow the new head skin change. ● Head and Body Morph - Each character has separated head and body morph. You can change a character’s body morph without affecting his or her face shape, and vice versa. ● Additional Base_IBL and Base_RTL projects are provided for the easy light scheme change, it also lets users start with an absolute neutral body shape. Note : ● RTL stands for Real Time Lighting, optimized for projects that are lit up with real lights without using IBL. You can find all Elite character content under their corresponding CC3_RTL folders after installation. Pack includes: 10 Head Morphs (Morph Preset) 6 Body Morphs (Morph Preset) 21 CC Characters (2K Texture x 11, 4K Texture x 10) 21 CC Skins (2K Texture x 11, 4K Texture x 10) 10 Full Body Morphs (Morph Preset) 11 CC Teeths 30 Avatar Presets (Body x 10, Head x 20 - 2K Texture x 10, 4K Texture x 10) 2 Projects (Neutral Base for IBL and RTL) 1 CC Lightroom (RTL optimized for real light render) 11 CC Eyes (optimized for both PBR and Traditional Shader) Please find out more from the product page HERE.
By kungphu - 8 Years Ago
What hair is used for the promo pics and where do we get them to make a full character per the promo pics?
By FAITH BASED GAMES - 8 Years Ago
kungphu (11/5/2018) What hair is used for the promo pics and where do we get them to make a full character per the promo pics? Yes that is one of my questions as well, especially Travis' hair! LOL!! :)
By TonyDPrime - 8 Years Ago
"Failed to initialize content install module of Character Creator 3.02"
Looked at this page, different error, but still attempted troubleshooting, with no effect: https://kb.reallusion.com/General/50341/How-to-fix-Failed-to-connect-to-the-internet-error-when-execute-the-Installcontentrlcontent-for-Windows-OS
Any ideas how to fix, other installs recently installed no longer working either?... (By this I mean .rlcontent files, they all give the error)
Also gives error if I try to use an iClone-specific install. I confirmed I am not using a proxy server. Is there a latest version of RL downloader, I have 2.27, is that the latest?
TonyDPrime (11/7/2018) "Failed to initialize content install module of Character Creator 3.02"
Hey Tony, I hope that this will help....I don't know a whole lot about iClone and stuff, still really a noob at this. Are you using the Reallusion Hub for your installs....if not you can get that here > Reallusion Hub maybe that will help. If that doesn't help you can take a look at this LINK to see if there is something more that might help you out. Again I hope that helps. maimas :)
Thx...
RL - strange, there were posts in past about others with this issue for other users... I do have a log, that is produced in: C:\Users\<user name>\Documents\RLDownloaderMgr.log
And I think it is telling me that there is a Proxy issue, however in the Control Panel it is not selected, and in the Registry it is set as "0", for off, meaning it should not be a Proxy server error. But maybe this log says something else I don't see with my basic-user eyes
13:13:19 Debug: scope id: "" 13:13:19 Debug: ===>CHttpPostWrapper::IsInternetConnectionActive(): listOfProxies Number : 1 13:13:19 Debug: ===>CHttpPostWrapper::IsInternetConnectionActive(): Proxy(0) Type: 2 13:13:19 Debug: ===>CHttpPostWrapper::IsInternetConnectionActive(): connectToHost: 1 13:13:19 Debug: ===>CHttpPostWrapper::IsInternetConnectionActive(): Connected Successed: 13:13:19 Debug: ===>PackInfo-PackName: "Elite Characters" 13:13:19 Debug: "Has Proxy : true, ( Proxy Count : " 1 " )" 13:13:19 Debug: 1 "/" 1 " proxy type is " 2 13:13:19 Debug: ==>Block Thread(false). ConnectGetFile 13:13:19 Debug: ==>Use GuiThread Download. ConnectGetFile 13:13:19 Debug: Has Proxy : true ( Proxy Count : 1 ) 13:13:19 Debug: 1 / 1 proxy type is 2 13:13:19 Debug: ===>Metadata changed( 15232 ) 13:13:19 Debug: ===>Ready Read Http, (Buffer Size : 15232 ) 13:13:19 Debug: ===>Finish Http Link trigger action 13:13:19 Debug: ==>Block Thread(false). ConnectGetFile 13:13:19 Debug: ==>Use GuiThread Download. ConnectGetFile 13:13:19 Debug: Has Proxy : true ( Proxy Count : 1 ) 13:13:19 Debug: 1 / 1 proxy type is 2 13:13:20 Debug: ===>Metadata changed( 67920 )
Ran again and now see this:
13:44:21 Debug: Repacker Lib load error : "Cannot load library C:\Program Files (x86)\Common Files\Reallusion\Downloader\Repacker2\cc3\RLVnsRepacker3.dll: The specified module could not be found." 13:44:21 Debug: Load Repacker API version: 2 13:44:21 Debug: InitCntDecrypter Error : 10 , RepackerDLLPath : "C:\Program Files (x86)\Common Files\Reallusion\Downloader/Repacker2/cc3\RLVnsRepacker3.dll" , RepackerVersion : "2"
But that .dll is in there, but is from 2016....How can I get a newer one? Or, is that even the issue....:hehe:
By Kelleytoons - 8 Years Ago
Yipes -- what a PITA. I'm kind of glad I didn't see this post before I bought this pack, or it might have deterred me (but I had no problems).
If this were me I'd at the very least try uninstalling the Hub and install again and see if that doesn't fix things. Then it's off to a trouble ticket.
Well, I tried the most basic step of them all....and it WORKED :blink:
I powered down, turned back on PC. Loaded the file, and Boom....working. :w00t:
So, if anyone ever has this issue, try turning off your PC and trying again...I didn't change anything registry or setting-wise, but I did try reinstalling the Downloader program..maybe it needed a reboot to get itself in flow. You know, I noticed this on Win 10, though, which seemed to not be the case in Win 7... Sometimes, if you have had the PC running for a long time, like say >1 day, it just starts having issues with things, especially if you have used a lot of applications. So, in general, if you have some fluke issue that cannot be identified and it is mind-perplexing, it may be Win10 going kaplutz on you.
By mortalez - 8 Years Ago
Thx... RL - strange, there were posts in past about others with this issue for other users... I do have a log, that is produced in: C:\Users\<user name>\Documents\RLDownloaderMgr.log
stuff like this is why I hate reallusions way of downloading content, whats wrong with a simple zip file with the content we pay for that we can easily add to a custom folder?
TonyDPrime (11/7/2018) Well, I tried the most basic step of them all....and it WORKED :blink:
same thing happened to me a few times, again another reason to hate the downloader. my desktop goes months without rebooting as I never know when an idea will pop into my head and I need to get started on it before it leaves my head and waiting for everything to reboot is just enough time to lose an idea.
HAHAHAHAHAHAHAHA....been there done that! 😊
Glad to hear that that was all it took! :D
By ian_11 - 8 Years Ago
Could someone clarify what is the difference with this pack vs importing DAZ characters pro & cons thanks, guys?
maybe is was a dumb question:
Group: Forum Members Last Active: 1 second ago Posts: 33, Visits: 1.1K Could someone clarify what is the difference with this pack vs importing DAZ characters pro & cons thanks, guys?
I'm not sure there are "pros and cons" -- it's like saying what is the difference between two people? These characters have skins and morphs just like the Daz ones, except they look... different, just like each and every Daz character is different from each other.
The main advantage to getting this pack, IMHO (and why *I* bought it despite having hundreds of Daz avatars) are the eyes, which are custom designed and can be used for any character. I could have made similar ones myself, but for the price (I got $20 off so it was $79) getting these characters, the new skins and morphs AND the eyes was just too irresistible. But everyone needs to decide for themselves.
By animagic - 8 Years Ago
@ian_11: There are no dumb questions, but I couldn't think of an answer in this case...:unsure:
I agree with what Kelley stated and would add there is also a certain convenience of having it all ready to go. That said, the DAZ import has been working very well for me, so it's certainly an option as well.
By jd_mann - 8 Years Ago
I just purchased the Elite Characters, after buying the Crazy Talk 8-Pro, two days ago..... I have read all the problems everyone is having and i am unable to get this downloaded or installed.......of course, I am way out of my water on this....but if anyone finds a solution, please post it....Thank you
jd_mann (12/28/2018) I just purchased the Elite Characters, after buying the Crazy Talk 8-Pro, two days ago..... I have read all the problems everyone is having and i am unable to get this downloaded or installed.......of course, I am way out of my water on this....but if anyone finds a solution, please post it....Thank you
The Elite Characters pack is for Character Creator 3 only. This pack won't work with Crazytalk 8. Do you have Character Creator 3?
i do not know,,,i am going to check....thank you
I have a MAC. the Character Creator 3 is only a Windows program.... so i guess i am screwed...nuts thank you for your information .
