Hello!I'm sitting in an animation that consists of single-sided movements, which are then repeated on the other side. When I start the project, I can still copy symmetrically within the first clip. Not later then. It works again when I merge clips. But then he doubles the movements and the copies can not be changed symmetrically. When I delete the copies, the avatar turns off completely and assumes strange attitudes.I also tried to put all the movements in one clip, but I just do not get the result, which I want with defined transitions, etc.Who knows advice?Thank you.
