OBJ not showing up when trying to make clothes
Home
Archive
Character Creator 3
General
https://forum.reallusion.com/Topic389195.aspx
Print Topic
Close Window
By Danny_B
7 Years Ago
Hi all,
I've got a .obj file, which I'm trying to use to make custom clothes for my characters. I click the 'create/cloth, hair, acc..' in Character Creator and select the .obj, which was exported from Blender. It shows up under the scene, however it does not appear in the viewport. Toggling visibility doesn't seem to do anything to make it visible. Has anyone else run into this?
By Matt GH
7 Years Ago
It may be because Blender OBJ scale behaves in strange ways. Your imported model is there, is just so tiny you can barely see it.
Try to select the object from the SCENE list menu, then press R to pop up the scale gizmo and resize it to the proper values.
By raitan2008
3 Years Ago
I am having the same problem.... how much of a scale up is needed to see it?
By animagic
3 Years Ago
raitan2008 (6/12/2022)
Scale is 100. Blender measures in meters and iClone/CC in centimeters. 100 cm is one meter.
