By TonyDPrime - 6 Years Ago
In the past I have FBX exported out with materials but in 7.3 it is just giving roughness and metallic, any thoughts?
By animagic - 6 Years Ago
It should export all texture maps, not just Roughness and Metallic.
I tried this and got the same result, so what you need to do is uncheck "Embed Textures". This will save out all texture maps separately.
By Kareeem - 6 Years Ago
Even with embedd textures On the textures are exported. They are included in the FBX though. Unity or UE4 can extract them though. Its a bit inconvenient...why store the textures at different locations.
@k.rehimi: you are correct; I assumed that Tony wanted the textures separate for some reason.
By Rampa - 6 Years Ago
The metallic and roughness are always exported into a separate folder because the FBX file does not support them. Having them in an external folder allows you to then load them in your other software.
