Characters won't look at each other
Home
Archive
iClone 7
Technical Issues
https://forum.reallusion.com/Topic385827.aspx
Print Topic
Close Window
By rightdecis
6 Years Ago
After installing an update to the graphics of my computer, I can't get the characters in IClone 7 to look at each other or look at anything. Is there any set of keys on the keyboard to make them look at each other?
By TheOldBuffer
6 Years Ago
In the avatar modify panel there's a section called "look at". Pick "look at" target, job done.
By rightdecis
6 Years Ago
I've tried that. It doesn't work.
By TheOldBuffer
6 Years Ago
rightdecis (10/9/2018)
Make sure to refine "look at" target or it will look at the root.
By rightdecis
6 Years Ago
I don't know what that means. But I've tried manually selecting the "look at" from the menu on the character and the side bar and neither works. Can I use nay alternate keys on my keyboard?
By AncientWire
6 Years Ago
There is an update
https://forum.reallusion.com/385369/iClone-7322051-Temporary-Update-Available
By Postfrosch
6 Years Ago
Today came over the RL HUB an update for IC 7.3
"Look at" works again
Greets from Germany
Postfrosch
By pruiz
6 Years Ago
AncientWire (10/9/2018)
There is an update
This link does not go to the update only the general page for Reallusion forum. Where should I look please?
By LogicalWarrior
6 Years Ago
pruiz (10/9/2018)
There is an update
I posted the same inquiry as you. If you would like to refer to my post, then you may do so. It was fixed in the new update. The problem was with any older Gen characters. If you had any G5's or older, the feature didn't work, and I reached out to Peter and company about it. He responded in my post that it was fixed, in which it was because I'm using it now as we speak.
Cheers!
