By Colonel_Klink - 8 Years Ago
I just installed ver 1.55 of the content uploader but it will not run on my HP laptop. When starting the Uploader I get this warning
I cannot change the resolution from 1366 x 788. Anybody got any ideas?
Further to this the Readme.txt file that comes with Content Uploader says: System Requirements ================= Minimum System Requirements: . Pentium III 800 MHz (Pentium IV or higher recommended) . 256 MB RAM (512 MB or higher recommended) . 512 MB disk space (1GB or higher recommended) . Display Resolution: 1024 x 768
By Miranda (RL) - 8 Years Ago
You are right. The display resolution requirement in readme.txt is inconsistent with the reality. We may be able to modify the resolution of Uploader, and make it compatible with 1024*768. I will keep you updated when the new version is available.
Thank you Miranda.
I sent the dev file to you via email on Monday, please let us know how it works, thanks!
Thank you Miranda. I'll install it and report back. Cheers Bob
Hi Miranda. That version worked good thank you.
Good, thanks for your confirmation!
By Contentstock - 7 Years Ago
Hi ! I got the same problem, could you please send me a compatible version of content uploader ?
thanks!
By Miranda (RL) - 7 Years Ago
Contentstock (1/20/2019) Hi ! I got the same problem, could you please send me a compatible version of content uploader ?
thanks!
Hi Contentstock,
The new version is just uploaded to the webpage, please download it again, thanks! https://developer.reallusion.com/submit.html
