frame count render confusion
https://forum.reallusion.com/Topic385517.aspx
Print Topic | Close Window
By johnwarndt52 - 8 Years Ago
Hello, My first trial animation render was set up for frames 1-3000 of my project, but it only rendered half of that. Does anybody know what I might be doing wrong? Attached is a screenshot of what happened. Thanks.
https://forum.reallusion.com/uploads/images/cfa4e2ac-c20d-4c00-acb5-4386.jpg
By wires - 8 Years Ago
iClone uses an internal frame rate of 60 frames per second (fps). 3000 frames equals 50 seconds of video.
If you render a 50 sec. video at 30 fps NTSC standard then you end up with 1500 frames. A PAL render of 25 fps gives you 1250 frames, and a film standard render of 24 fps gives you 1200 frames.
No matter which way you look at it you still end up with 50 seconds of video.
Thanks, Wires.
