Unity3D Remesh Opacity
https://forum.reallusion.com/Topic384929.aspx
Print Topic | Close Window
By julesd - 7 Years Ago
USING CHARACTER CREATOR 3
When using the Remesher InstaLOD check marked, with Unity 3D preset.
I cannot find the Opacity map for things like the hair in Unity.
I have tried telling Unity to use the Diffuse image Alpha as transparency but nothing.
Because the mesh has been combined, I only have the diffuse map and the normal map as main textures.
Where is the Opacity Map?
it has not been attached to the diffuse map. Even though it is checked.
I am using Genesis 3 Character. Everything used is from Daz3D.(hair,clothing,shoes)
Also used Amplify Shader to create my own material, still cannot get a Alpha from diffuse to use as a mask.
By justaviking - 7 Years Ago
julesd (10/3/2018)
Would you believe me if I said it was omitted by design?
It has been reported.
Everything requiring an Opacity Map, look odd without it. Thanks. I hope they focus on Daz imports. Especially the eyes, the cornea and eye moisture always ruin the outcome look. I have been playing around with 3D since they created a cube on the Commadore Amiga, and still to this day there are always problems transferring 3D models. Mostly in the transparency area. We need to reduce the amount of 3D formats out there.
My Daz characters always have problems with the eyes.
And thanks for being honest.
