So lost. Struggling with basic G3 models
https://forum.reallusion.com/Topic383333.aspx
Print Topic | Close Window
By gkscoot - 8 Years Ago
Howdy,
I'm hoping someone can advise me on 2 basic issues.
1) I can't afford Photoshop. I have a bunch of other bitmap editors, and the one that seems to actually be able to save as .PSD and keep layers is https://www.photopea.com/ but this is online, so you can't direct CTA3 to use it. Can I do a save as locally and work around that way? Since photopea won't return the file directly back to CTA3, what would be the process?
2) The reason I haven't tested the above is to be honest I am really struggling with the process. I have tried to follow the CTA_G3_WhitePaper_Character_Creation.pdf a bit. Let's just say I think I need a video.  (I did find the video on sprite replacement pretty easy. But I'm looking for the pipeline process videos). So doing a search on Youtube for "crazytalk animator 3 pipeline tutorial" there are 72 videos in one group. I have no idea where to start.
Re allusion does have a ton of videos. I've found 1, "Animate a Character from 6 Body Parts" which looks pretty good, but seems to use the writers own custom project and files.  So, is there videos out there that explains the G3 character PSD Pipeline process with actual sample files that we have access to?  Forgive me for being dense here - there are so many videos out there that I feel overwhelmed trying to find just one I can follow with files provided. Maybe someone has been where I am now and can offer some advise?
Thanks a bunch!
By kylelee - 8 Years Ago
Hi, the online PSD editor was supported with CTA3 pipeline version.
But only the Launch External PSD Editor did not work.
If you would like to import PSD, the Photopes is compilable.
https://forum.reallusion.com/uploads/images/0dedc37c-b081-48c7-b7ca-f8d9.gif
By vepop - 8 Years Ago
Hi gkscoot,
Come join the CTA3 FB GROUP.
Perhaps the members there can help you with the issue.
Here is the link:
https://www.facebook.com/groups/crazytalkanimatorusers/
Hi Kylelee,
Wow !!!!! Oh man. Thank you SO much. I really appreciate the work you put into your answer. Very clear, and encouraging. You are a good person, I can tell :-)
Thank you again :-)
Thank you vepop, I will definitely check out your FB link.  Thanks for the quick answer!
P.S. Edit: I applied to join - its a closed group. So while I am waiting, if someone just happens to have a link to a video that makes sample files available to follow along with the PSD Pipeline process for G3 characters, please post it. Thanks!
