By Miranda (RL) - 8 Years Ago
The new Character Creator 3 Transformer tool converts Daz Genesis 1, 2, 3, 8 and Michael 4, Victoria 4, HiveWire FBX content to the Character Creator 3 character system, ready for face and full-body animation, and able to be optimized for games with multiple LOD.
- Transform, morph, mix and blend Daz characters into Character Creator.
- Optimize Daz characters and assets for animation, games, VR and AR.
- Enable Daz characters, clothing, accessories and props into animation-ready assets.
>> Find more details from the webpage.
*The official tutorials will be provided in the following days. You can refer to the following guides to have some advanced techniques on DAZ content import, especially helpful for content developers.
Step 1: Export Character with Morphable Assets from Daz Studio
Loading the character, setting the morph export rules, and exporting in FBX.
- Load a single Daz or Hivewire character inside Daz Studio.
- Export the character as FBX with all of the proper Morph Export Rules –these same morphs can be used in CC3.
- Collect all of the textures of the character into a central folder directory. If you don’t have them ready at hand, you can you browse for them in the Surfaces section of Daz Studio.
Step 2: Import Daz Character with Full Texture ChannelsUsing the Transformer tool and setting the cloth layers to import the Daz character. - Open up CC3 and click on the Transformer button in the top toolbar menu and select FBX file exported from the previous steps.
- In the following Asset Import Status Report click on Bake Texture Profile button to create an INI file.
- Leave CC3 for now and open up the INI file in a text editor. In it you will see all of the materials applied to the character along with their texture channels. This is where you can map the texture names to their appropriate channels.
- If you are mapping a channel to a texture: use the file name along with its extension type in quotes. For example: “DawnSEArmsB.jpg”, “DawnSEArmsD.jpg”, etc.
- If the texture is already embedded in the FBX file you can just fill in USE Embed Texture.
- Fill out the INI file as much as possible and save it.
- Back in CC3, click on the Texture Profile load button to select the INI file.
- Do the same for Texture Folder, this time for the centralized texture folder.
- Make sure Bake Body Texture is enabled.
- Set the Bake Texture Quality to High if you are making content for the Reallusion Marketplace or Content Store.
- Click OK to start the baking process and afterwards you should have a CC3 character that resembles the Hivewire character in Daz Studio.
*Note: Character Creator support roughness/metallic PBR textures. Please add PBR textures if there is none in the original character. Step 3: Check Hair Morph in CCProcess on verifying the hair morphs. Step 4: Check Cloth Morph in CCProcess on verifying the cloth morphs. Step 5: Optimize Cloth MeshInstructions on cutting down the mesh count on the clothing to make it suitable for real-time animation. Step 6: Optimize Cloth Mesh by ElementInstructions on cutting down the mesh count for portions of the cloth to make it suitable for real-time animation while maintaining shape integrity. - You are allowed to optimize mesh on the selected element, or have different optimize settings for the selected element and the deselected elements to conduct optimization all at once.
- Morphs are no longer supported after polygon optimization.
By max767757 - 8 Years Ago
I'm trymg to import Victoria 4 in from Poser 11. CC3 gives an error stating "Incompatible profile" and fails to import. Any thoughts?
By luke (RL) - 8 Years Ago
did you update to the newest version? Both CC and pipeline https://www.reallusion.com/character-creator/update.html
I have the latest updates. I may try to rout her through DAZ and try to import her through there. Am I correct in saying that even though I successfully imported her into iClone 7, That avatar WILL NOT open in CC3?
By Peter (RL) - 8 Years Ago
max767757 (11/7/2018) I have the latest updates. I may try to rout her through DAZ and try to import her through there. Am I correct in saying that even though I successfully imported her into iClone 7, That avatar WILL NOT open in CC3?
If you import your Victoria 4 character using 3DXchange 7, then it will be a Non-Standard Character in iClone and not a CC compatible character. Non-Standard characters can't be opened in Character Creator 3.
For the issues you are having using Transformer, do try stripping all clothing and hair from your character and try to import just the nude V4 figure. Does this still give a profile error?
By ken_1171 - 7 Years Ago
Kelleytoons (4/28/2019) What particular Daz item are the gloves?
It's the "Scifi Siren sleves" for G2F.
By Kelleytoons - 7 Years Ago
That's very interesting -- my gut tells me this is something to do with the way the gloves are constructed, but even changing them to accessories (or weighting them as different clothing items) didn't help.
If I were you I'd report this as a bug in FT (I would do it but I really don't care much about polygon reduction and have far bigger fish to fry).
By Rampa - 7 Years Ago
Try exporting each one as an OBJ. Import each into CC3P as an accessory, then use the Transfer Skin Weights function on each one separately. You can try both the "glove" and the "other" settings.
Betcha dollar it won't make any diff, Rampa -- this is a problem with the mesh, not with how it comes in.
(And the gloves aren't separate pieces, so no wiggle room there).
Thank you guys for all the feedback on this. I have checked the mesh in a 3D modeling program, and it indeed has a series of issues. I have tried to clean up the mess, but even after the program stopped identifying issues, CC3 would still not handle the right glove properly. It makes no difference how we load the model. I am not going to report this as a bug because, like Kelleytoons said, the problem is with the geometry.
I have noticed another issue, this time with a hair item ("Power Hair" for G2F), where whenever I try to assign a dynamic map to one particular MAT zone ("Side 1"), iClone crashes immediately. I have managed to assign a map for dynamics to all other MAT zones, just not that particular one. This is easy to reproduce, because I have tried a couple more times, and it always crashes iClone right away (version 7 x64 with all updates). Now I wonder if this is also caused by bad geometry.
By Peter (RL) - 7 Years Ago
ken_1171 (5/1/2019) Thank you guys for all the feedback on this. I have checked the mesh in a 3D modeling program, and it indeed has a series of issues. I have tried to clean up the mess, but even after the program stopped identifying issues, CC3 would still not handle the right glove properly. It makes no difference how we load the model. I am not going to report this as a bug because, like Kelleytoons said, the problem is with the geometry.
For the glove and hair issues, please can you supply your files (FBX, iProject etc.) to Support so the dev team can investigate. The dev teams initial tests showed no problem as can be seen below so it will help greatly if they can test with the same files. Thanks.
By Tarampa Studios - 7 Years Ago
First option to solve this is to try widening the stance of the character at position 0 on the timeline in Daz BEFORE EXPORTING and locking the pose with legs apart enough that nothing touches.... then you can reload a standard pose in 3DX or iClone later.
Otherwise it can be solved by taking it into cinema 4D or another mesh modelling software and manually shifting the polys that intersect each other.
Altho there could be another easy way, those are the 2 that always work for me. 😊
Thank you guys so much for the feedback - I was really stuck on this!
I understand there is a drawback for not using the CC3 T-pose back in DS. How exactly do I recover the default pose later on in CC3? I suppose there should be an extra step to compensate for the non-standard pose, right?
The upper body clothing transfer sometimes does better in a T-pose. So go ahead and put the character in a T-pose in DAZ, and then rotate the legs out a little for the lower body in an A-pose. Then export the FBX for the transformer.
Yup, that's what I did - I have applied the CC3 T-pose and then separated the legs so there was no overlapping, and exported to FBX. I was surprised that after Transformer did it's job, the figure was set back to the CC3 T-pose on its own, while having the extra bonus that the boots were no longer welded at the middle. I thought I would have to recover the default pose afterwards, but at least for the legs, Transformer did that on its own. I couldn't see any fitting issues so far, so I would assume I can do this with no setbacks for future outfits that overlap in the middle.
Even Transformer has a warning message at the bottom, claiming I should make sure the figure is in the expected CC3 T-pose, but this has worked out even when the legs were not in the expected pose. I am not sure what to think of this, but I am happy it has worked anyway. I was pretty sure there would be a setback if I didn't use the default pose, but [so far] I didn't see anything.
Ok, I am now having another issue, this time with InstaLOD. The boots are separate objects in DS, and after Transformer they now show as a single pair of boots, instead of each leg being separate like it was in DS. When I InstaLOD them, everything works fine. The problem shows up when I do the same with long gloves, where each is a separate item in DS. After Transformer, they show as one piece for both arms, but when I try to poly reduce them with InstaLOD, only the left arm is affected. I have tried this with all InstaLOD options, like by object, by wearables, and by element. Both arms appear as selected, but InstaLOD only decimates the left arm. I have tried by element, specifically selecting the right arm, but the left one gets decimated instead. In theory, this shouldn't make a difference, since both arms get selected when I click the gloves, and this same process has worked with the boots - but it doesn't work with the gloves.
Any ideas?
Following your methodology is successful. Thank you for that. I thought I was doing something wrong by importing WITH clothes. I'll chalk this up to inexperience as I am anxious to change my primary platform over from Poser 11 to iClone 7. Thanks again for answering my questions accurately.
By R Ham - 8 Years Ago
DAZ into iClone is something I've tried to do many times over a long stretch of time. I've never been satisfied with the results. Not even close to satisfied. I'm going to give it another try in the near future, this time using CC3. This particular topic is where I'll be spending time. I'll have stupid questions aplenty. "In order to learn, it is first necessary to admit you do not know." So I figure, the stupider my questions are, the more I will learn. :)
To me, DAZ into iClone is one of the Grails. I'm looking very forward to this.
Be seeing you...
Here's a fast easy solution for complex morphs that won't export from Daz to 3DX or CC...
I morph and use characters from Daz on a regular basis, often mix-n-matching clothes with their own morphs from different generations.
So when my creation becomes too complex for 3DX or CC to import, I start getting error warnings or crashes without warnings...
UNTIL.. I learned to "ARC Freeze": It's drastic, and creates a permanent new morph slider in your library (unless you delete it later)... but it's fast easy, simple and works, and it creates avatars that can be exported straight into CC or 3DX WITHOUT needing to waste time adding extra export rules:
MAKE A SINGLE DIAL BASED ON MULTIPLE DIALSHow to take multiple dialed in morphs and make a single controller for them in DS - works for Gen 2 & 3, so far as I've had time to check... - Select the figure you are working with; we are assuming that morphs and bones are already set in a way you want to ERC freeze them
- Go to top bar menu, select Window -> Panes (Tabs) -> Property Hierarchy
The new pane should either pop up or open up on left or right, depending on your layout If you are working on say, Genesis, it should show Genesis already selected.. but both times I've done this, I had custom clothes which also showed up, so it didn't automatically select the avatar until I did it manually... - Right-click on your Genesis in Property Hierarchy pane and you’ll see the ERC Freeze option (all others could be grayed out, it is ok)
- In a next screen the Figure/Node is Genesis
- Property – > Create New
- Name it whatever you want and Put the Path for the actor where you prefer - I haven't bothered playing with any other parameters yet, like limits etc.
- Unclick “Create as empty morph”
- Press ‘Create’
- Unclick Restore Figure Rigging on the bottom of the screen (other two should be selected).
There should be a bunch of things (that you dialed before) already selected. - Accept.
- Check if it works.
- Save as morph asset.
This saves the morph slider WITHOUT a thumbnail image... so if anybody knows how to add a thumbnail image to a new Daz morph slider INSIDE DAZ, please let me know...
During this process it looks like we also get the option to sell our new combo-morph slider in the Daz Store, but I just want my own library to look tidy. NOTE: THE ABOVE INSTRUCTIONS ARE ADAPTED FROM a Comment that I found in the Daz Forums that was posted on: March 22, 2016, by : 3dOutlaw. I can't find the original thread sorry... but it was only a semi-relevant question by someone who was having a similar problem importing into Carrara.... 3DOutlaw replied with these very helpful instructions which didn't help the Carrara dude, but certainly helped me...
Please also note: The original Morph Freeze Instructions - ARE HERE: http://3doutlaw.com/home/?p=1571 - but they also advised that we should dial the morphs back to zero before saving the new morph, however that wasn't working for me in my Daz 4.10 version, which wasn't released until 2017, so I'm guessing the functionality has changed a little...
So I've also taken the following screenshot in case the link ever dies, or in case Daz changes procedures again, it helps to keep the historical chain of instructions together here in this forum:
Anita,
I saved this link because I wanted to have a bit of time to digest what you are saying here. It looks like you're telling us that applying various morphs in Daz and then exporting as FBX and bringing in via Transformer to CC3 doesn't work? I'd like to know of an example, since I do this all the time and have never had a problem. I'm not saying there isn't a problem -- applying morphs is almost unlimited and the combinations couldn't possibly be all accounted for, but I'd sure like to see just ONE time this doesn't work (and I know the CC3 devs would like to know as well).
You don't have to post a file -- just like me know what morph combos you are using in Daz (I'm sure to have them). Let me see if I can figure out why they wouldn't just come into CC3 as they should (without messing around with anything -- you shouldn't have to do anything special for them to work).
When I use transformer to convert a pair of long boots, the required T-pose makes the legs intersect in the middle, and the auto-generated weights end up welding them together. When I try to select the faces from one boot, the selection tools don't seem to distinguish what geometry belongs to the left or right legs, so how to separate them? I have noticed that "Transfer Skin Weights" has an option for "Lateral Partitioning", but that only works if the geometry is not intersecting in the middle. I would appreciate any help on this issue.
First of all, you don't need to use the T-Pose -- this works if the clothing needs it, but often times another pose (like with the legs spread apart here) will work better for a particular item of clothing.
With such a pose you shouldn't have any trouble selecting the faces from one boot or the other if you need to position them better. But let me know if you do (and let me know exactly which boots they are, as I most likely have them and can guide you better).
