Will the new Iphones X (XS, XR) be compatible?
https://forum.reallusion.com/Topic379322.aspx
Print Topic | Close Window
By Pixel4Fiction - 6 Years Ago
Hi guys, I tried, in vain, to know if the new iphones X would be compatible with the Liveface module ... I indeed tested Faceware and I'm not very satisfied with the result despite all "good" stuff of my modest studio (lighting, Hexacore, HD 60 fps camera, 2xTitan X, 64 GB DRAM) ... I was disappointed also by the rather negative comments (well, not all) on the forums about faceware (although it must be said that the setting must be longer to achieve to have something perfect) ...
Before investing in an iphone X ... I would have liked to know if the plugin and profiles will be compatible with the new Iphone XS, Max and XR?
Thanks for your reply.
FRED
By animagic - 6 Years Ago
The new iPhones being quite expensive, someone would need to supply RL with them in order for testing to be possible. My understanding of the new phones is that the essential hardware is similar, they just have faster processing.
Thank you Animagic for your reply. This is precisely to avoid investing in a model that may become "out-of-date" ... technically; knowing that the Mocap requires a lot of system resources. Then, if the arrival of new Iphones can lower the price of the old ... it will be quite good.
By Arul2022 - 6 Years Ago
I have Iphone XR and it works fine with plugin and other assets
