CC Pose?
https://forum.reallusion.com/Topic379249.aspx
Print Topic | Close Window
By mark - 8 Years Ago
I'm sure this has been asked and answered before but...I happen to have a pose I like in CC2 and wondered how to get that pose into iClone? The posed avatar always comes into iClone as a "T" pose. Anyway to change that so the pose in CC2 is the pose I get in iClone?
Thanks!
By Am7add9 - 8 Years Ago
hi Mark,
this isn't exactly what you asked but....
I'm pretty sure all the CC poses are also in iclone 7 in the motion/pose directory.
Sure you're correct but I did some tweaking in CC and wanted "that" particular pose to transfer into iCone.;)
By Peter (RL) - 8 Years Ago
mark (9/13/2018)
Thanks!
Hi Mark
In CC2 the avatar is exported in the default pose which is the T-Pose. However if you open the Pose Editing panel (N), you can pose your character and then press "Set As Default". Your custom pose will then be the default and will the one exported with your .iAvatar. Note: You can switch this back to the t-pose from the Calibration panel.
However in CC3 this all changes. In CC3 you will have a Pose entry in Content Manager where you can save your custom poses as .rlMotion or .iMotionPlus. These can then be used in iClone 7 and vice versa by simply dragging and dropping the pose onto your character.
Thanks for the info Peter.
I swear I had tried the "Default" pose setting in CC2 and it didn't seem to transfer to iClone but I'm sure it was me doing something wrong.
Looks like CC3 is going to be da-bomb!!:P:D:P
