By YAZHL - 6 Years Ago
Hi ,
I am a newbie for animation. I am using crazytalk animator 3 pipeline version. I need some help on how to change the color of G3 character at some specific position. I understand we can use Render style to change the color of object. But i want to change the different color at different frames. For example : At "frame 1" i want the color of object as "RED" . and at "frame 20" i want the same object color in "BLUE" . How to do this.
Thanks,
By jlittle - 6 Years Ago
Render Style colors can only be changed for the whole timeline and not frame by frame (as far as I know). You can change colors by adding another sprite for that part, same shape but in a different color and switching sprites at various frames.
Jeff
By Edward (RL) - 6 Years Ago
Seems the only way is export the scene to a png or psd file, and adding the color filter on an external image editor (Photoshop, Gimp, Photopea.. ). After that, bring it back to CTA as a one frame Image Layer. Not a good solution, but should work.
By Ibis Fernandez - 6 Years Ago
duplicate the object. change color of second object. use visibility controls to toggle between the two.
