Support for custom Camera Angle Animation Export
https://forum.reallusion.com/Topic377901.aspx
Print Topic | Close Window
By taka_ - 8 Years Ago
Hi reallusion people
I am having troubles exporting animations made with crazy talk, I am gonna explain it:
1 -  I made a simple animation of a door opening
2 - I go to 3D view and I move the camera to set the door in a diagonal position, until here all works great
3 - I play the animation in Crazy Talk Animator and I can see a door in a lateral angle opening. PERFECT :)
4 - :( :(  When I export the animation it doesn't export what I am playing in crazy talk, it exports the door opening from a front angle, it doesn't take care of the angle I gave
Please Reallusion team solve that
I think it shouldn't be that difficult to implement this feature in a next update, it is something you already have working it is just the export of the animation what is not working.
Could you consider this? It would make your software better
By vepop - 8 Years Ago
taka_kush
The 3D view is for viewing only.  It also helps to position the characters/props.
You can try using Prop Key Editor/Deform to get the effect.
Otherwise create the door to have the diagonal position.
