Shadow through the wall? How to remove?
https://forum.reallusion.com/Topic376137.aspx
Print Topic | Close Window
By dogged2003 - 8 Years Ago
How to remove the shadow on the wall? From lamps from inside?
https://forum.reallusion.com/uploads/images/557f872e-b748-46c0-823e-3583.jpg
Thank you so much.
By Lamias - 8 Years Ago
I would try to scroll down the modify panel. You will see these settings that have to do with shadows.
https://forum.reallusion.com/uploads/images/36312710-c07e-4468-9e69-18b7.jpg
I think it will be solved if you choose the one on the far right, but feel free to experiment with these 4 buttons.
By animagic - 8 Years Ago
I had a look at the scene (the Loft Scene), and I was able to find a solution. It is kind of weird...:crazy:
For each of the Spotlights (listed under Spotlight in the Scene Manager), set Darkness to "0".
https://forum.reallusion.com/uploads/images/60bab481-94c0-4ef0-8c0d-dc38.png
The shadows are now gone:
https://forum.reallusion.com/uploads/images/5fc63c8b-7f2f-4d33-b356-2444.png
Animagic
Wow! That beats me! How did you guess?
dogged2003 (8/15/2018)
Animagic
I had to go through all lights actually, because there wasn't any object that could cast those shadows. But they disappeared when shadows were turned off globally, so they had to come from somewhere.
I think this could actually count as a bug, because the "shadow" shouldn't go through the wall. You can almost consider it to be "negative light", because it is the inverse of what's cast on the inside wall.
