LIVE FACE ( iPhone X ) Profile
https://forum.reallusion.com/Topic375622.aspx
Print Topic | Close Window
By Tony (RL) - 8 Years Ago
https://forum.reallusion.com/uploads/images/09f3ea6f-5dfd-4b99-8dee-5208.jpg
Here is the dedicated forum of the LIVE FACE ( iPhone X ) Profile for Motion LIVE Plug-in.
Learn how to make it work from the Manual, and don't hesitate to share your thoughts and works!
By davood.kharmanzar - 8 Years Ago
really?! Oh my GOD !! this is real !!
and its time to say goodbye to noisy Faceware :]
By pgibouin - 8 Years Ago
What is the difference beetween Faceware and Live Face for iClone ? Faceware is much more expensive (990 euros vs 249 euros for Live Face) but works with a middle range webcam around 100 euros. Live face is cheaper but require an iPhone X to work, wich costs 1129 euros in Europe with 64 GB memory (less if you subscribe a contract with an operator but still around 650 euros).
What is the best solution for facial animation into iClone ?
Thanks Reallusion for all the work you make for animation community, it's just amazing ! I see mocap and facial animation like the future of 3D and 2D animation...
By animagic - 8 Years Ago
If you happen to have an iPhone X it seems to be a better and more flexible solution. It is attractive that a lot of processing is done in the phone.
Also, licensing FaceWare is a headache (especially when trying to use it with MotionLive). Maybe competition will entice the FaceWare company to clean up their act and take Reallusion and iClone seriously
By mtakerkart - 8 Years Ago
Hi Tony and Thank you. In this video :
I repost my youtube question: at 4:30 you said that an infra-red sensor is requiered. I understand that for a z-depth data.
Does that mean (because it's an Apple device) that is Faceshift algorythm ?
If so , I'm shure that this technic is more accurate as the Faceware techno , is it?
(I used the two)
By charly Rama - 8 Years Ago
Great new, it's time to buy an iphone X, the only reason for me to spend so much money for a phone. It will be superior to faceware because of faceshift
By R Ham - 5 Years Ago
Hi,
I'm not doing well connecting Live Face to Motion Live.
I followed the Ethernet instructions here:
https://manual.reallusion.com/Motion_LIVE_Plugin/ENU/Content/iClone_7/Pro_7.0/29_Plug_in/Motion_Live/Connecting_to_LIVE_Face.htm
They were easy to follow. But, the Add Gear button was disabled.
I'm wondering if a critical bit of info is left out of the manual.
Any help is appreciated.
Thanks.
By animagic - 5 Years Ago
In case, you (or others) are still struggling, after the IP address you needed to add the port number, which is always "999".
So if the IP address indicated on the iPhone is 192.168.1.33, the connection string to enter in Motion Live is 192.168.1.33:999.
animagic (8/9/2021)
Yes, thank you, I spotted that. My problems are more advanced today, your comment would be welcome.
https://forum.reallusion.com/492088/LIVE-FACE-Does-it-have-an-eyebrow-problem
By shoaibkhan1315910008 - 7 Years Ago
iPhone is one of the phenomena of mobile phones in this generation. It's expensive but is worthwhile and really good to use it. But All these electronic products sometimes it's not working properly so here I suggest the UAE technician provides the best service for the iphones user so you easliy take the services.
iphone screen repair
By gosolo2 - 6 Years Ago
Live Face and Faceware has a lot to catch up with the original Faceshift from almost a decade ago. Please correct the blendshapes in IClone ( a job for Reallusion ). Bring back the old Faceship or fix Live Face ( this is a job for Apple ) so we could have a descent face mocap.
To be honest Live Face ( the old Faceshift which was broken by Apple and Faceware with IClone are very disappointing). The results are unnatural and robotic. It is not Faceware and Live Face ( although the new Faceshift  trapped on the body of Live Face and broken by Apple ) faults. The blendshapes for Iclone characters don't have the proper 51 standards blendshapes necessary for a smooth face mocap and they are faulty ( sometime you have to correct them ). When you see the results from videos made by the IClone experts using Faceware or Live Face and compare to Faceshift made in 2012 by enthusiasts at that time, you realise how bad IClone with Faceware and Live Face really are. I have both, Live Face with Iphone and Faceware. I also have Faceshift which doesn't work with Realsense RS 300 camera and Windows 10 unfortunately. Funny how many people don't want to see the invisible new clothes of the emperor. Sorry, English is not my first language.
By azin.khanloo - 5 Years Ago
Hello,
I just installed motion live plug-in but I can maximize, scroll down or extend the motion live plug-in window. I wonder what is the issue and how can I fix it.
By Kelleytoons - 5 Years Ago
What's your screen resolution?  And what scale is Windows set at?  And did you change the iClone settings for larger text?
By Trender 3D - 5 Years Ago
Hey Azin,
I just want to find if you found a solution to this dilemma because I’m having the same problem - where I cannot open my Motion live window fully. So I can’t access the bottom section of the face or the tick boxes at the bottom of the window?
Allistair
By pedrosura - 7 Years Ago
Problem with New Computer (Fast) Iclone 7.41. I am getting the character to freeze. The Live Facve App is detecting my face correctly but the character is freezing. The FPS is showing 60 fps so;lid the whole time so it is not Iclone that is freezing but the character. Any ideas on what might be causing it?
My Wifi connection seems to be working without problems and when I swtiched to another router I kept getting the same issue. Any ideas??
By Hookflash - 7 Years Ago
Does Live Face support the iPhone XR as well? Thanks!
By Kelleytoons - 7 Years Ago
Yes it does.
By TonyDPrime - 7 Years Ago
I watched the recent tutorial video and there are some things I will clarify,
I have tested with an iPad Pro 2018, an iPhone XR with no sim card, and with sim card:
-You cannot just use a USB cable
Motion Live never, at any point, indicates that it does not need an IP address because it 'sees a cable connection'.  It HAS to match the IP address of the Live Face app.
Like, it never says "USB connection" or anything of the sort.  You cannot avoid the inputting of an IP address.
By synth_image - 7 Years Ago
I am having similar issues. Did you get it working?
By Hewa' s Art - 7 Years Ago
Hello, I Purchased the LIVE-FACE-Profile-for-Motion-LIVE-Plug-in with LIVE FACE (iPhone) Profile for Motion LIVE 2D Plug-in ( Bonus ) .
i can't install the plugins for both iClone 7.6 and Cartoon Animator v4.02 Pipeline. getting this message when installing the plugin. Should I have to buy and installing Motion LIVE Plugin too or there is something wrong.
By pedrosura - 8 Years Ago
Keep getting "Faceware live.. 10.10.19.79:802 Connect to server failed" I am using the same wifi between desktop and iphone X. The Iphone app is working. My IP on the iphone app is 10.10.19.79            Why is the server failing?? Any ideas???
pedrosura (8/19/2018)
Hello, I think that you choosed the wrong plug in if you get error saying "FACEWARE LIVE connect failed".  It's not about faceware but LIVE FACE, try to write 10.10.19.79:999 instead of 10.10.19.79:802, your port is wrong , it's 999 and not 802.  And make sure you installed the profil live face at motion live
Thank you for the reply. I consequently downloaded the latest update Face Live and used the face Live plugin. Still unable to connect. It says Face Live server failed. Desktop and iphone on the same Wifi network and same IP code. Port is 999. I am going to try to use a USB connection to see if I can get it to work.. It should work with Wifi..
does exists an plans to support iPhone XS and XS Max??
By arthurchengvr - 8 Years Ago
Hi~
   I just bought motionLive and testing it with iPhonex. It works great  but I got strange curve after exporting fbx to max and maya. (see bmp)
Anyone has this issue too?https://forum.reallusion.com/uploads/images/f8843599-547c-466b-8b79-f15b.bmp
davood.kharmanzar (9/13/2018)
Hi davood.kharmanzar,
The newest LIVE FACE App does support
iPhone XS and XS Max.
Please update your app via Apple Store.
Hahaha! Completly forget to connect the Iphone  to my wifi .... Now it woks AND IT'S AMAZING!!!!!
By chrispnpro - 8 Years Ago
chrispnpro (8/10/2018)
Hi !
Just downloaded motion live and face live d.o.
 Connected my Iphone x to my router via wifi.
Started iclone with a character, activated motion live and changed the ip adress accordingly to the ip adress in face live on Iphone x.
The green Icon was activated in motion live.
Now this happens:
When activating the character the preview and rec button lits upp for a few seconds and then iclone crash and dissapears.
There is a crash dump and a log but i dont understand.
Yes i have a ticket to reallusion and waiting for anser but during the time maybee there is somebody who rec this issue.
Best regards
Back again…. uppdated the relevant plugins via HUB and voila it all works perfect….
By raphaelrichards_33 - 8 Years Ago
Faceware cheek puff doesn't work there are no tracking points for them
Faceware should definitely try to do better to avoid a mass migration ... even for a cut down version of their product it's very limited .
I agree with you, in this video , I show what can we do with faceshift which is not possible with faceware
[/quote]
Ok , I had confirmation by Tony on youtube. I'll wait to get CC3 to play with and I think I'll leave faceware for Faceshift alias "Live Face" ;).
Do Motion live allow to connect 2 live face performers simultaneously ?
Hi !
Now this happens:
Best regards
By Peter (RL) - 8 Years Ago
mtakerkart (8/10/2018)
You can control either multiple characters with one iPhone for facial mocap, or you can connect with multiple iPhones to drive multiple characters’ faces. :)
Thank you very much Peter. Very exiting to play with !
impossible to connect to my Iphone , I have a failed error to connect....
My IP Iphone is 127.0.0.1 , I write it and leave the :999 but no success.  Is it normal the double dots before the 999 ?
The Iphone live face works because the data change on my Iphone.
Any Idea ??
