Fortnight Emotes
https://forum.reallusion.com/Topic375038.aspx
Print Topic | Close Window
By EvilGenius - 8 Years Ago
I have a bunch of animations from the game Fortnight that I want to bring into iClone.  They are in FBX format.  However when I try and load them into 3dxchange they wont let me.  I converted to non standard character but still, it wont allow me to do it.  Can someone help me?  I have over 50 of them but I need someone to tell me what settings to use in 3dxchange.  Here is one of them as a example.  THANKS!
https://1drv.ms/u/s!AvUAhdROn95hgclqTpd7PDQgPpGFdQ
UPDATE:
So I imported these FBX files into Blender and it recognized it.  Someone on forum PM'd me and suggested I export out of Blender as a .bvh file then import into 3dxchange.  That appeared to have worked.  It loaded into 3dxchange.  However if I send to iClone it loads but only the character, not the motion.
Suggestions?
By tripfreak - 8 Years Ago
I have no idea why your 3DXChange makes problems ? :ermm:
I just gave it a try, assigned all bones in 3DX 5
https://forum.reallusion.com/uploads/images/86c53eb3-56c8-4e87-bd0b-f29a.jpg
and converted the char including the motion:
Right model by U-like (once free): LINK
You can find the motion and the 3DX profile: here
Fingers not absolutely correct but I didn't spend too much time with it...
By dogged2003 - 8 Years Ago
It's fine. Can anyone tell me if I have 6 and 7 3dx pipe line, do I need to buy a fifth? Or can I download it in my account? Because they didn't work as good as 5 3dx :)
P.S. I tried to convert by Autodesk FBX Converter Archives, it issued an error. The blender worked. But knees were not correct.
So if I export out of Blender as a .bvh and then import that into 3dXchange, this is what I see.  It doesnt show the avatar like in @tripfreak screenshot.  Which is cool and all, I dont want the avatar.  Just the motion.  The motion works when I press play in 3dxchange.  However when I "send to iClone" the character is motionless.
https://forum.reallusion.com/uploads/images/2cdbf4d1-08d3-4403-a91f-a027.png
Try use File - Export to iClone. Set mark on motion. I far away from the computer.
Send to IC work only for prop movements.
dogged2003 (8/3/2018)
I tried your suggestion and this is what I saw.
https://forum.reallusion.com/uploads/images/e5c8366b-7d33-4dd9-98a4-d0e0.png
