Resize image
https://forum.reallusion.com/Topic374967.aspx
Print Topic | Close Window
By limtaiwah - 8 Years Ago
How o you resize an image on the canvas?
By Peter (RL) - 8 Years Ago
If you select the image by clicking it you should see a bounding box. You can then click and drag the corners to resize.
By Cory Chang - 8 Years Ago
Hi, limtaiwah
When you apply an image on the canvas, you can resize your props as followings:
1. Select the image, and drag frame to resize it.
2. Or select the image, and you can change the size on the right panel (Image Setting).
Thank you.
Best Wishes
Cory
https://forum.reallusion.com/uploads/images/519fa1f5-5515-477b-85be-b581.gif
