By toystorylab - 8 Years Ago
Never tried "Mirror", watched some tutorials long ago, most of them quite lavish (but more accurate)... Since i really need a mirror for current project, i decided to give it a try... Simply put a cam in the center of mirror and played arround with cam-settings (Focal Length + Angle of view)...
Rendered cam and put in Diffuse-Chanel of mirror. Also here played around with settings till it worked (mirror horizontally!).
Quick and dirty, Animation had NO priority and it took me from 0 (empty project) to 100 (finished result in Hitfilm) ca. 2 hours... Mirrors are no problem anymore for me, even when the result scientifically is no accurate reflection. And the effort is really minor (place cam in mirror and render...) :D
By Kelleytoons - 8 Years Ago
Yeah, I did one in about 10 minutes.
To do it accurately (with the right angles) would be a no-brainer if we had robust Python, but I doubt whether I'll ever see that (the Python they will release sounds pathetic). Then it would be a one-button push solution.
By Walt_R - 8 Years Ago
toystorylab,
Nice. Thank you for posting this. Should be quite helpful in the future. :)
Walt
By animagic - 8 Years Ago
Thanks for the mirror tip, toystorylab. This will be most useful. As long as it is believable, it will be good enough for me.
By bexley - 8 Years Ago
While is isn't very accurate, it certainly solves a problem I'm having!
Thanks for the tip!
