Only Four Videos per Project!
https://forum.reallusion.com/Topic373891.aspx
Print Topic | Close Window
By Britlish - 8 Years Ago
I discovered a limitation in iClone yesterday, while making my latest video English lesson. I wanted to use iClone to introduce some videos into my project, but iClone interrupted and said that I had reached the limit of 4 videos. I had a choice of making around 8 separate projects, 4 videos to a project, or trying something else. I opted for the latter and used After Effects to introduce the videos after rendering the narrator in iClone. It worked okay, but I would have liked to have been able to put the videos on animated screens in iClone instead.
Any idea why there is a 4 video limit on iClone?
By Kelleytoons - 8 Years Ago
I've used more than 4 videos -- are you sure it isn't a memory limitation with your GPU?
And how and what are you using?  (I use Popvideo, on billboards).  I haven't tested this in a while (not since about 7.1) but I can test again to be sure.
By TonyDPrime - 8 Years Ago
This video has some great video clip moments.
@5:04 is BRILLIANT.
I am also very familiar with @6:21....probably got caught watching @6:32
Great video!
By toystorylab - 8 Years Ago
Can't confirm this...
Quick test with 17 videos (mp4) as plane or billboard:
Win 10, gtx 1070
Then it must be to do with the 3D VFX Motion Montage Vol 2 action panel, Blinds-Whole, that I was using, rather than iClone in general. I will try using different action panels for the next video and see what happens.
Thanks for your help, and your positive comments.
Well, the panel you mention only has 4 (3+1 side) slots to insert a video :D
I just checked having 3 Panels (Blinds Whole) in my scene, each of them can carry 3 Videos...
So, that were 9...
https://forum.reallusion.com/uploads/images/ac95c351-3c2e-43d0-99cd-9d10.png
