How to remove butterflies?
https://forum.reallusion.com/Topic373202.aspx
Print Topic | Close Window
By dogged2003 - 8 Years Ago
Hello!
Tell me how to remove butterflies? It started to rain, but they are flying?
https://forum.reallusion.com/uploads/images/9719408c-a610-4dfd-97ab-783a.jpg
And why are the settings so truncated?
How would they plant flowers?
Can RL make a webinar of using butterflies in a scene with trees, flowers, animals, sun, wind (changing), rain?
Thank you.
By Postfrosch - 8 Years Ago
Excuse me,
but what you want to do works: See screenshot above
- butterflies fly (butterfly switch on)
- Rain starts (rain switch on on)
- butterflies do not fly (butterfly switch on off)
- stronger rain begins
- Rain ends (both rain switch on off)
- Butterflies start to fly again (butterfly switch on)
I'll do flower plants soon
Greets Postfrosch
Short TUT of Flower Plants (its IClone Basics - TreePlants works also)
Greets Postfrosch
The correct question is 90% of the answer.
My butterflies fly slowly and smoothly. And do not want to disappear in the rain.
I attach a screenshot, video and project.
I am grateful for any advice, how do I remove the butterflies?
https://forum.reallusion.com/uploads/images/2f8542f4-76a8-42b6-b21d-cee2.jpg
By hj - 8 Years Ago
Hello
here my results. I used your project.
more details in the german part of RL Forum
I hope it helps a bit
Hans Jögen
By 4u2ges - 8 Years Ago
I also made some enhancement. They fly away as the rain starts.
project
By hj - 8 Years Ago
hi 4u2ges
You have to reduce the Lifetime at frame 724
try this
https://forum.reallusion.com/uploads/images/3dc54447-9153-4ac8-bac0-1238.jpg
here the clip with your version of the iProject with my corrections
i hope this help you
Hi hj,
If I do that, they would abruptly disappear at 12th second (when rain start), which is kind of unnatural (although that is what OP wanted).
It was rather an artistic choice to give them another 3-4 seconds to fly away in panic.
That is why I set height, flying and flapping speed to max for those 3 second and at 15th second they are completely gone (because I reworked the lifetime), even though the effect is still on up to the end.
By hj - 8 Years Ago
Hi 4u2ges
that was not the question.
The question was "how to sopp the butterlys"
May some butterflys a still alife, because "off" means no more new butterflys, but not the dead of the living butterflys:P:P
If you do, how i show you, no more new butterflys will be created by the emitter after the  "off" frame
best
Hans Jörgen
